How do I move an email that I accidentally sent to Trash or Spam back to Inbox with Thunderbird Mobile for Android?
I have TB Mobile for Android Version 8.2 on my Samsung A54 running Android 14. I have done numerous searches, but can not find any way to move an email that I accidentally sent to Trash or Spam back to Inbox (or any other folder for that matter). Am I missing something or is this feature simply not available?
I can do the above with my Yahoo mail on my A54 which has a menu that lets me move any email from folder to folder.
Thanks for any help.
Wayne Mery மூலமாக
தீர்வு தேர்ந்தெடுக்கப்பட்டது
Method 1: (In the email list) select the email by long-pressing it or by tapping the icon before the email > tap the vertical three dots on the upper right corner > "Move".
Method 2: (Inside the email) tap the vertical three dots on the upper right corner > "Move".
Method 3: 3.1. You can configure swipe actions to "Move": "Settings" > "General settings" > "Interaction" > "Swipe actions" > configure action for "Right swipe" or "Left swipe" to "Move". 3.2. Then you can right-swipe or left-swipe the email to move it.
If you do not see "Move" after tapping the vertical three dots, the following steps might be helpful: "Settings" > "General settings" > "Display" > "Visible message actions" > tick "Move" > "OK".
Read this answer in context 👍 2All Replies (1)
